03-23-2021 11:03 AM - edited 01-06-2022 01:32 AM
Im looking to replace my current phone and was looking at getting the Lg k32, Was wondering if I bought it prepaid from koodoo or telus if I would be able to have it unlocked immediately or if there is a wait period?.
03-23-2021 01:41 PM
Thank you! I am going to go with one from Chatr and wondering if there was a way I can find out if it the "bands" are compatible as it is not showing up on the search list on public mobile
03-23-2021 11:25 AM
03-23-2021 11:09 AM
Thank you very much!
03-23-2021 11:06 AM
@diesel85 : If it's a new phone, it'll be unlocked.
03-23-2021 11:06 AM - edited 03-23-2021 11:07 AM
@diesel85 wrote:Im looking to replace my current phone and was looking at getting the Lg k32, Was wondering if I bought it prepaid from koodoo or telus if I would be able to have it unlocked immediately or if there is a wait period?.
There is no wait period. However, the phone should already be unlocked. In most cases, Telus-locked device don't need to unlocked to use them at Public Mobile, regardless.
