Unlimited data at reduced speeds
GaijDelaneu
I purchased the new 65$ a month over 3 months subscription. I see I have 150GB at 5G speed. It says something about unlimited data at reduced speeds. How does this work?
marcusward
Even worse, Lucky is 128kbps and Chatr is 64kbps.
@DennyCrane wrote:
For perspective, 512Kbps is 0.5Mbps. I.e. practically unusable for much more than basic messaging.
I don't agree wtith that.  512Kbps is more than good enough for browsing sites such as this Community, internet-based phone calls, steaming audio, maps/navigation.  Netflix would even work, though the experience won't be enjoyable.
hi @DennyCrane download the map first amd the data is enough for navigation LoL
but at least better than Lucky 256 amd Chate 128
DennyCrane
hi @GaijDelaneu when you used up your regular data allotment, your data will still work but at reduced speed of 512kbps. Not good speed but enough for email, chat or Google map
@GaijDelaneu  Once your 150GB gets used up it will be throttled data at 512kb until your next renewal and start over with 150 Gb again
