05-30-2023 02:08 PM
I have been trying for about 4 days to subscribe to a plan and then port my number from Koodo to PM. This has been unsuccessful so far. Can you assist with the process please?
05-30-2023 02:39 PM
HI@SadieGirl , are you activating NEW PM account?
or you have an existing PM account and try to link ot the new Sim card?
05-30-2023 02:38 PM
I have an email address and a password but cannot activate my sim card.
It is Not an ESim card.
05-30-2023 02:35 PM
IH @SadieGirl
for prepaid koodo, you have to take my suggestoin above
, you can choose to activate a new number first. Then once activation is done , either use the app or My Acocunt to request porting or submit ticket with agent to request porting help
05-30-2023 02:33 PM - edited 05-30-2023 02:37 PM
@SadieGirl Then in that case activate a temp number then contact support to port your Koodo number to the new pm account , like i mentioned in my first post to you
05-30-2023 02:32 PM
I am reinstalling the PM app on my phone and yes, the Koodo plan is prepaid.
05-30-2023 02:28 PM
HI@SadieGirl it should work as long as you are not subscribing $25 or $15
PM is one email one account. So, logoff your current acocunt ( @SadieGirl ) first
When you subscribe, you need to use another email address for the new account
(unless this @SadieGirl account is not liinked to any My Acocunt)
05-30-2023 02:26 PM
Trying to subscribe on the website.
05-30-2023 02:10 PM - edited 05-30-2023 02:11 PM
@SadieGirl Have you downloaded the new PM app to activate , also are your planing to port from Koodo pre paid or post paid ? If post paid follow prompts ,, if pre paid activate the SIM card and then contact support to port the number for you
05-30-2023 02:10 PM
HI @SadieGirl
were you using App or subscribe on the website?
if you are subscribing using eSIM, there has been problem and not sure the ETA
and what error you got?
and if you try to port from Koodo , you can choose to activate a new number first. Then once activation is done , either use the app or My Acocunt to request porting or submit ticket with agent to request porting help
