Unable to make calls outside of Canada
Nizarjr
Hello
I am unable to make calls outside of Canada, despite having the can/usa/mex plan.  Keeps telling me im out of minutes when i try to call even to the US.  Can I please get some support to have this resolved
9 REPLIES 9
hi @Nizarjr
then still try the Reboot and Reset Network Settings
if same, ask PM support to refresh your account for you
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Nizarjr
@hTideGnow  - but im in Canada. Im trying to dial from Canada to the usa 🙂
hi @Nizarjr
your phone is good
make sure you call by dialing 1### ### #### or + 1 ### ### ####
also, try reboot phone and reset network settings
if still fails, try the different US networks, AT&T, T-Mobile and Verizon
Nizarjr
Still no luck and support also hasn't been any help. I'm trying to call from Canada to US but keeps telling me all available minutes are used. Im on the $35 can/usa 60gig plan on a s24 ultra
Dunkman
@Nizarjr
Where are you physically located right now?  USA?
Which model phone are you using?  VoLTE compatible with PM network?
@Nizarjr wrote:
@eddieO  - tried rebooting several times no luck
Hey @Nizarjr
Try this. Go into your Settings and find Network Settings. Reset the network settings and then restart your phone. This should help you reset your connection to Public Mobile and show the proper account. If you are having issues still connecting to a US network, go back in to Settings, Carrier Settings and turn off automatic. My opinion is T-Mobile is the most reliable in the US so pick that and then make sure data roaming is turned on. Then reboot the phone. Moving forward when you visit the US, your phone will always remember this setting and you'll never have to fuss with it again.
@Nizarjr just read online that some are saying to wait at least 10 seconds before turning the phone back on. If this still does not help try contacting a support agent.
try sending a private message to:
Regular business hours are from 9 AM-10 PM EST. Responses are typically given within an hour, but it may be longer depending on current volumes so keep monitoring your community inbox.
Nizarjr
eddieO
@Nizarjr try restarting your phone, this usually clears up the issue
