12-08-2021 12:46 PM - edited 01-04-2022 05:01 AM
I forgot to disable my call forward before travel to US. I want to receive call in US and bough roaming add on. But unable to disable it. Receive error: Problem connection or invalid MMI code. Please disable call forward of my account, any help from Agent will very appreciate. Thank you.
12-08-2021 02:20 PM - edited 12-08-2021 02:24 PM
@tanvuvuong : All of the above (Edit: list of instructions) only applies while connected to this place....Edit: as you discovered.
12-08-2021 02:18 PM
@softech : Yeah that's why I asked if he had actually tried rather than assuming. 🙂
12-08-2021 02:17 PM
reading some old posts, I think if you phone is reachable in the US , then call forwarding will be "broken' right a way.
If it registers on a US network, forwarding will be broken until it can register to a Canadian tower:
You shouldnt have your issue. that calls still being forwarded. So, is your US roaming indeed working?
12-08-2021 02:16 PM
12-08-2021 02:12 PM - edited 12-08-2021 02:13 PM
call forwarding is an account setting and not device. When you set it on the device, it actually sending the command to the network for your forwarding choice.
I suggest you to open a ticket with CS Agent and see what they can do . Again , tell them you have bought US Roaming and hence need this to be turned off
Just to confirm, but with your roaming, you can make calls without problem?
12-08-2021 02:06 PM
12-08-2021 02:01 PM
I don't think a CSA can help you....this is a phone setting not an account setting. Try @t_p 's suggestion if possible. Where did you call forward your number to?
12-08-2021 01:58 PM
12-08-2021 01:54 PM - edited 12-08-2021 01:56 PM
@tanvuvuong : You will have to contact CSA for this. Follow the instructions to submit a ticket, from the second post here.
@Anonymous : can you edit your first reply in this thread to say “...double post...” only? That will look cleaner 👍
12-08-2021 01:53 PM
@tanvuvuong wrote:I forgot to disable my call forward before travel to US. I want to receive call in US and bough roaming add on. But unable to disable it. Receive error: Problem connection or invalid MMI code. Please disable call forward of my account, any help from Agent will very appreciate. Thank you.
Try Reset network settings, or Factory reset.
12-08-2021 12:57 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck...
12-08-2021 12:54 PM
For US Roaming 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only 10 day packages
250MB = $10
500MB = $15
1GB = $20
when you visit US and then Purchase it,
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link..
