Unable to add funds
Vanity91
Hello
I have been trying to add funds to my account to top it up but when I click on where it says to add funds I get an error message that says that either the link is broken or it is under construction. I need to top up before August 22 when my plan renews. Can someone tell me how I can do this?
Regards
Wendy Hayes
10 REPLIES 10
@Vanity91 wrote:
Thank you so much for your advice. I cleared my cache and browsing history and that seemed to work. I was able to add funds to my account
self solution removed
Vanity91
Timer
@Vanity91
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
To Login Page
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything
just wait a 5 second automatically be login,,
and vouchers added to your account by call *611
once connected press (1) then (1) again and enter the 12 digit PIN #,
if you still can't then contact support team by CS_Agent
MrSpock
@Vanity91 hi if you are using a voucher you can dial *611 on your phone to pay also if you know your pin you can pay with your credit card if you have one on file
HI @Vanity91   It could be just browser cache.
Try to login to My Account again using Incognito mode, or try on another browser like Edge/Firefox/Chrome or try on another device.
You have enough time to add fund, just try with the tricks above.
If that still does not work, open ticket with PM Support
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
