11-21-2023 06:42 PM
When I tried installing the esim for my new account, it said it was unable to activate and suggested try installing again or contact carrier for assistance. When I did this and tried to scan the QR code again for the esim it says it's unable to download.
Already tried rebooting iphone with no success.
Any suggestions?
11-21-2023 09:00 PM
Just heard back from CS agent. They are going to reimburse the $5 for the esim. Nice!
Kevin
11-21-2023 08:34 PM
The solution from the customer service agent was to download and install another esim. Once we did this, it worked right away. Not a big deal, but this esim wasn't free whereas the first one was with the Black Friday sale. Surprising that there is ever an esim charge since it is just a small chunk of software delivered over the internet.
Thanks for all the responses!
11-21-2023 07:10 PM
If you're encountering issues activating an eSIM on your iPhone and rebooting hasn't resolved the issue, here are some additional steps you can try:
Check Internet Connection: Ensure you have a stable Wi-Fi or cellular data connection, as this is necessary for downloading and activating the eSIM.
Clear Previous eSIM Profiles: If you have previous eSIM profiles installed, try removing them before installing the new one.
Update iOS: Ensure your iPhone is running the latest version of iOS, as updates often include fixes for connectivity issues.
Reset Network Settings: Go to Settings > General > Reset > Reset Network Settings. This will reset Wi-Fi networks and passwords, cellular settings, and VPN and APN settings you've used before.
Contact Carrier: If the issue persists, contact Public Mobile for assistance. There might be an issue with the eSIM profile or activation process on their end.
11-21-2023 07:01 PM
@Kevinc63 , if it would’ve installed I would suggest this after reboot your iPhone which worked for me:
In cellular settings make sure that ‘Turn On This Line’ is selected & reboot your phone. (You may need to reset network settings then reboot)
Please let us know what the CS_Agent says.
11-21-2023 06:48 PM
use this link to message Customer Support to assist your activation..
watch the little envelop icon in top right side of this page will be highlighted when they respond.
