06-12-2025
08:25 PM
06-13-2025
12:22 AM
computergeek541
06-12-2025 08:48 PM
If you downloaded the PM app and unable to purchase the eSIM, then your phone is unlikely eSIM compatible.
https://www.gsmarena.com/ulefone_armor_28_ultra_thermal-13297.php
Looking at the specs, your phone may not support eSIM. May need to purchase physical SIM card.
06-12-2025 08:40 PM
You might need to activate with physical sim first, then try changing to esim after.
