01-28-2024 11:21 AM
Hi I bought USA add on's when I was in LA for the weekend.
They didn't work at all I tried all the help your bot gave me at the time like restarted my phone , selecting different networks etc.. nothing worked I couldn't use my phone at all , no calls no data
I bought 2 add on's on Jan the 4th can I get a refund for them please. It cost me 45$
02-12-2024 10:28 AM
@Kfortin According to your other thread you were in Mexico, which is not part of the USA and therefore a US add on does not work there. Public Mobile does not have roaming elsewhere than the USA. You need to contact customer service at the links you were given to try for a refund.
02-12-2024 09:13 AM
Did you get a refund? I bought an add on that didn't work also and was wondering how to get refunded. I tried all the fixes they suggested also and none worked.
01-28-2024 08:42 PM
@Phil_Adelphus - That is true, I did hear that when I was looking at T-Mobile.
01-28-2024 12:09 PM
@fixin Also that trick will soon be retired, since T-Mobile is removing their 2G network in April ish this year.
That's good to know - I just found an article that said T-Mobile has announced April 2 for the 2G shutdown. That's going to make US roaming even more problematic for people without a VoLTE phone!
01-28-2024 11:25 AM
Ask agent for refund.
US add-on is not that reliable anymore due to USA network change. People should use free voip apps and off-line maps for navigation or dedicated GPSr (Garmin).
01-28-2024 11:24 AM - edited 01-28-2024 11:25 AM
What you may wish to know, however, is from the point of purchase, they only last 15 days.
So if you bought them on January 4, and your travel occurred AFTER January 19, they would have expired by then. Additionally, you can only use 1 at a time, then re-buy the same one or add a different one after it expires. All the preceding could have impacted your ability to have US services via PM Roaming.
Still @flafffel , perhaps you might want to contact the support agents to advise.
01-28-2024 11:24 AM
@flafffel - Is it possible that your phone isn't VoLTE Compatible, if not, go to T-Mobile and Selecting 2G as the network option. Also that trick will soon be retired, since T-Mobile is removing their 2G network in April ish this year.
01-28-2024 11:22 AM - edited 01-28-2024 11:22 AM
Chances are the support agents will do this for you @flafffel
Just be patient and polite with them, letting them know you tried the recommended actions.
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
