USA Travel
Pipcan
I will be going to USA for about 30 days and want voice/text/data.  Is it available with PM or should I buy a SIM card in USA for this?
2 REPLIES 2
hairbag1
For an extended US stay...my suggestion is to get a sim in US and a cheap 30 day plan. When you get to US, check your local Walmart usually have some decent priced, short term plans.
PM only has the 10 Day US roaming options as explained above. Many reports of poor talk available and iffy texting...probably depends on which area of US you're going to be in. With the PM option..forget connecting to AT&T. I found that only T-Mobile works but give a try to Verizon, if you do go with the PM roaming options for talk.
dust2dust
For that length of time get a USA sim. You could buy the 10 day roaming add-ons 3 times for $60 and maybe extra data too. Do the math.
Get a data-only product and then use a voip app and set up a Canadian number. Then you can forward calls to that number. Leave the Public sim behind.
