USA/Canada plan
Hawkeyerffr
I was sure I did the change on the promo even got a message it would change on the 14th of the month, for some reason I don't have it and the plan has gone
will it come back? Or how cn I get it added
9 REPLIES 9
Hawkeyerffr
That's the one hope it comes back
Hawkeyerffr
Probably lol
Lemony_Snicket
This seemed like a good and unique plan that nobody else offers.  Too bad they took it away like they were concerned it would end up being too popular.
When you say US/Canada plan, do you mean a plan that allows calling from Canada to Canada and the USA? If so, the regular $50/8.5Gb plan includes calling to the US.
if you mean a plan that allows travelling in the US and calling anywhere in Canada or the US while there, the only plan that offered that was $60 and was available from around June to Aufustvbefore being removed from the list of available plans. Thus you could not have scheduled a change to it in the last 30 days.
AE_Collector
Hawkeyerffr
No I'm still in the plan one below that
Hawkeyerffr
This was an actual plan not an add on for $60 USA/Canada included roaming and 2g data while in USA
hopefully it comes back
totalUser
What plan do you have now?
What does your plan details page say?
What is listed in your add-on section?
If you have a 2g data listed and 8.5 that you are using, most likely you so have it. For done reason they don't say it explicitly but that 2gig is USA roaming
ChuckYeah
The us plan I remember had a poor description attached to it. Did not say us features are included maybe?
kennycrowshaw
USA add-ons last 10 days then you have to renew
