07-18-2019 05:43 PM - edited 01-05-2022 05:57 AM
Hi,
I bought the "US Roaming - Unlimited Talk (10-day)", but it doesn't work (I am at California now). I noticed that the "US Roaming - Unlimited Talk (10-day)" I bought shows the under the "Plan and Add-Ons" in my account. However, it doesn't show under the "Overview", which is weird. Thank you in advance for your help.
07-18-2019 06:04 PM - edited 07-18-2019 06:12 PM
Edit: Posted as a response to the post above, but has been since deleted.
07-18-2019 05:58 PM - edited 07-18-2019 05:59 PM
07-18-2019 05:55 PM - edited 07-18-2019 05:56 PM
@andrewxie1990 wrote:Hi,
@andrewxie1990 That's because it's unlimited talk so the counter is not used. Did you just purchase the add-on? It might need some time to activate. Maybe try restarting your phone.
07-18-2019 05:51 PM
Also, check all the possible settings in your phone to confirm that it's a PM issue and not a phone one!
07-18-2019 05:49 PM - edited 07-18-2019 05:55 PM
Make sure you are connected to either AT and T or T Mobile
You paid for the plan but did you really buy and pick the plan.
07-18-2019 05:47 PM
I currently can't think of any possible solutions, but will get back to you.
In the meantime, send a message to the moderators and they'll respond in due time!
https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/22437
Click that link and then "send this user a private message" detailing the same problem 🙂
Good luck!
