07-12-2022 06:03 AM - edited 01-10-2023 08:06 AM
US Roaming Add ons: July 2022
Edit: January 10th 2023
Please see updated info on US Roaming and new links later in this thread to complement this post.
Edit:
As reported by many pm customers using pm's US Roaming add ons for the last few months AT&T appears to no longer be a roaming partner with pm. Please only try connecting to T-Mobile. However if you do successfully connect to AT&T please report your findings and location to this thread. Thx! (12/28/22)
Public Mobile's roaming partner's AT&T and T-Mobile began the decommissioning of their 3G (HSPA) networks this year (2022) with AT&T starting on February 22nd and T-Mobile on July 1st 2022. This affects the voice services in the US when Public Mobile customers purchase and use 10 Day US Roaming Add ons. Public Mobile posted the following notice on the add ons page at publicmobile.ca/plans earlier this year once AT&T began decommissioning their 3G network.
Important: As of February 22nd, 2022, some United States (U.S) carriers will begin turning down certain 3G/HSPA networks in the U.S. As a result, some customers using U.S. roaming add-ons may be impacted by differences in coverage or service quality (including 9-1-1 calls) when roaming in the U.S. This shutdown will not impact your service in Canada.
But how does this impact your services when roaming in the US? Public Mobile customers will still connect automatically (with the autoconnect setting in your phone) to AT&T's and T-Mobile's 4G LTE networks to send/recieve SMS/MMS texts and use mobile data (depending on the 10 Day US Roaming add on purchased). However US Roaming talk add ons and/or talk components of US Roaming bundles will be impacted. Until VoLTE is enabled for Public Mobile customers the ability to use their voice services will be dependent on the remaining network connectivity with its roaming partners.
AT&T is virtually unusable at this point for voice services with their 3G network decommissioning nearly complete. Going forward US Roaming Talk add ons can only be used by manually choosing T- Mobile. In areas where the 3G network has not been decommissioned customers will still connect to the 3G network for voice services. In areas that no longer have access to the 3G network customers may be able to connect to T-Mobile's 2G (GSM) network. In the coming months connectivity to T-Mobile's 3G network will also disappear until only access to their 2G network will be available.
2G networks have been maintained by some mobile network providers as it was the fallback option for voice services before VOLTE was developed for the 4G LTE network and still plays an important role for certain technologies and provides better signal coverage over long distances and building penetration.
T-Mobile has not confirmed a date for the decommissioning of their 2G network. Updates will be posted on their website. Your phone will automatically switch to 2G to send or recieve a voice call. You will be unable to text or use mobile data during a voice call.
This map shows T-Mobile's 2G network coverage.....
**Localized 2G network coverage can be found by using the link at the bottom of this post.
The best workaround for these issues would be to download a voip provider like textnow that offers free calling and texting on WiFi and mobile data. Purchase a 10 day US Roaming data add on. You can receive incoming pm SMS texts. You can send and receive MMS texts. You can send SMS texts on text now along with send and receive voice calls. MMS texting works but does count against your roaming data. Calls and outgoing SMS on textnow will only use your mobile data while away from WiFi. A US Roaming data add on will provide you with all of your services on your phone albeit in a slightly round about way.
For basic info on 10 Day US Roaming Add ons and how they work read the spoiler below....
Edit:
Removed info related to the old self serve account layout. And added new link to the 611/IVR map.
To visually navigate the 611/IVR system (or 1 855 4PUBLIC and enter your 10 digit phone #) rather than follow the prompts use this map/diagram here .
You will need to enter your 4 digit account pin # for all access beyond basic account info and loading payment vouchers (press 1 and 1 again to load vouchers).
Please note:
Public mobile has limited roaming coverage thru its partner AT&T in Alaska. T-Mobile does not work for roaming in Alaska. Better service may be best obtained from Alaskan mobile provider GCI depending on the purpose of your travel.
To see 2G network coverage for specific areas use the link below...
**https://www.gsma.com/coverage/#466
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
