08-22-2022 01:36 PM
Hello, The first option under Add-ons Bundle is "US Roam-Talk Txt 250 Data(10d)". Is this unlimited talk, or does it come from your monthly allocated minutes?
Thank you
08-22-2022 02:22 PM
I will be travelling to Chicago
08-22-2022 02:19 PM
I will be in Chicago
08-22-2022 02:10 PM
A lot of the connectivity issues would be fixed if Public Mobile had VoLTE support. It's become a necessity for basic talk functionality. Right now it's unclear how well the add-on will work.
08-22-2022 02:09 PM
@hairbag1 wrote:Yep...tried all the tricks....even cussing at PM. TextNow worked like a charm.
I'm afraid I can no longer recommend PM for the roaming add-on.
HI @hairbag1 I always think Roaming add-ons are expensive and hard to connect sometimes. When you cannot connect, you really cannot seek much help (not just PM, Rogers, Telus, Bell are the same.. the Support are not in US , they just won't be able to do much) I always think unless for a quick weekend trip, anything more than 3 days should go with local mobile data
08-22-2022 02:08 PM
@hairbag1- Even cussing?! Dang. That usually always works. 🙂
08-22-2022 02:05 PM
@dust2dust wrote:@hairbag1- You being a regular here, I assume you tried all the tricks. Not even dead simple, low bandwidth SMS eh? Yeah voip apps are pretty handy.
08-22-2022 02:05 PM
Hi @hairbag1 I think CS agent will refund it, for the lack of service. check with them
08-22-2022 02:01 PM
08-22-2022 01:57 PM
This past weekend, I wasted $8 for the US texting add-on for a daytrip to eastern Wa state. Texting service used to be good, but not any longer. Service was unreliable and spotty in areas that were fine in the past.
I won't do that again. I found I could use TextNow in a lot of wifi enabled places like Walmart, most cafes...even in the downtown core of one town had free wifi. I could call and text...for gratis.
No more 10 Day US roaming add-ons for me unless things improve.
08-22-2022 01:46 PM
HI @PMuser44 which city and state you are going? Generally , you can use T-Mobile's 2G network for voice, but not everywhere has it
08-22-2022 01:44 PM
Be very aware of severe problems with talk in the states. Text and data should be fine. For talk you'll need to connect to T-Mobile and your phone has to be able to use the old 2G and even that might have limited coverage. You might find the odd pockets of 3G here and there.
08-22-2022 01:43 PM
What state (states) will you be visiting ? If going to Alaska, be aware many PM customers reporting little or no talk available due to US retiring the 3G networks. Some other states also have eliminated 3G...you can manually select 2G for talk in some areas.
08-22-2022 01:38 PM - edited 08-22-2022 01:41 PM
@PMuser44 hi that is for use in the US but I wouldn't recomend it since the 3g shutdow it is not very reliable it is supposed to be unlimeted talk while you are there for 10 days it doesn't come off any us talk you may have here in Canada
08-22-2022 01:37 PM
Unlimited talk for 240 hours after the purchase is successfully made. Remember...it will only work whist in USA.
