US Canada Plan
yag193
Can 50 month plan be used in both Canada and US?
Does this plan include free call from Canada to US , free call from US to Canada?
I will use this phone in Canada and US, just wondering if the plan can fit my needs, thanks
Chalupa_Batman
Hey @yag193
Until recently, I had this plan. While in Canada I was able to call several places in the US. While I was in the US I was able to call pretty much everywhere in the US and back home to Canada. And with regards to the data, of course. Data works like home. I used it a lot doing FaceTime with family and friends back in Canada while I was in the US. I abused it like a rented army mule!!!
fixin1
@yag193 - Yes, any of those 50GB can be used in Canada with Public Mobile's (TELUS) coverage or in the USA by T-Mobile or AT&T. Make sure to set to LTE as 5G may be unstable.
And yes, free and unlimited calling from Canada usage to US number, US roaming to US number, US Roaming to Canada Number.
And you will need a VoLTE compatible phone, please check here if your device will work for calls within the USA: https://www.publicmobile.ca/en/ab/get-help/articles/volte
And the Canada-US plan offers unlimited usage in both countries so no barrier after a couple of months like Freedom or Rogers Canada-US plans.
Sansan
@yag193 yes its interchangeable between both countries.
Have to ensure you have a VoLTE enabled phone that can connect to T-Mobile or AT&T rooming.
