Trying to change my plan
Mozgurl28
I'm trying to downgrade my plan but I have no idea how. The chat tells me to go to overview and click change plan but I absolutely can't find that. Help?
@Mozgurl28 - this is found in your My Account.
Have you ever created / registered for a My Account before? If not, you can submit a ticket here to: Create My Account or forgot My Account email or password link
Meow
After logging in to your account go to Plan & Add-Ons, Click on Change My Plan, pick Plan and select Change plan on renewal date or Change plan now. Use little arrows at right hand side to navigate through plans.
@Mozgurl28
To change plan sign into my Account and go to plan add-ons tab and use yellow arrow to scroll thru 3G and 4G plans .
Once you find plan you want be sure to change on renewal date . So you don’t lose out on current cycle
hairbag1
@Mozgurl28
log in on a laptop using incognito mode. Go to your account / Plan and Add ons / Change my Plan (right side of page)...select the plan desired.
added example
