Tried to fix a sim activation issue and made it even worse
btios
I tried activating my sim card on the public mobile app (i’m on an iphone 😎 but at the last step, there was an error message. Trying to fix it, i logged out then logged in, but it asked for my sim card number. I put the details but it said it’s already in use. What do I do now that i’m stuck?
slusagm
@Stevensh
did you try message PM?  But it is late now, they probably won't reply until tomorrow
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
@CSA_PM
the symptoms that this customer describe have happened several times in the past few weeks. Is there something that we can suggest to help or is it customer support only issue ? Is customer doing something during activation that causes the activation attempt to corrupt ? Give us some hints if you can.
CSA_PM
Customer Support Agent
Hi there. I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@btios I have escalated your issue in behalf.  Support will reply shortly, please monitor your community inbox for their reply
@btios  And this was a brand new public mobile SIM card that’s never been used before ? If so and you already paid
send  a  private message   To CS_Agent
slusagm
@btios
PM can help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
