01-02-2023 07:29 PM
Have weird situation - My account with Toronto number has no problem texting from Toronto, Ontario -to Montreal ---However my phone won't text from Montreal to Toronto. My phone's setting has SMS and MMS enabled.
What is wrong?
01-03-2023 10:11 AM
@Tsawwassen is it working now? You tried any of our suggestions?
01-02-2023 07:33 PM
Well that is weird @Tsawwassen .
Can your phone call from Montreal to the Toronto number ? Just checking if the number was put on the blocking list by accident....or, is the Toronto phone set up to only accept calls from people listed in the contacts? Check the settings in the phone app.
Could you perform this task before and this is all of a sudden..if so, a network issue maybe?
Also, have you tried restarting the phone that is trying to text to the Toronto number? Removing and reinserting your SIM card may help too. Or, even a reset of the device's network settings.
01-02-2023 07:32 PM
Wow that's a weird one. Try:
01-02-2023 07:31 PM
Maybe try resting your phone @Tsawwassen
01-02-2023 07:31 PM - edited 01-03-2023 10:12 AM
@Tsawwassen voice and data work?
I guess you rebooted phone already? Are you on Android, try clear app cache or try a different text app
