Too many attempts
Simonlavoie3
I tried to login and I exceeded the amount of tries and now I don’t know what to do. What is the steps to unlock that?
1 REPLY 1
@Simonlavoie3   there is actually no more account lock, you can close the browser and try again if you want to
If you forgotten the passowrd, first try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
