07-18-2017 04:25 PM - edited 01-05-2022 02:28 AM
08-09-2017 12:41 AM
08-01-2017 05:58 PM
07-21-2017 01:56 PM
07-21-2017 09:18 AM - edited 07-21-2017 09:20 AM
Try
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,dun
If those dont work see this guide from the community
07-21-2017 09:08 AM
Tethering didnt work on the original / automatic APN settings when putting in my PM sim card for the first time. So I looked on the internet got a different set of APN settings and tried that. It worked. Try another APN setting, worse case you can go back to your origrinal one.
07-19-2017 10:40 AM
07-18-2017 05:53 PM
07-18-2017 05:31 PM
@Icygod wrote:
I active tethering, but my iPad can't connect to wifi.
It should work, PM has no restrictions. I would have to say there must be a problem with your iphone or ipad. You should try to test another sim from another company to see if that works, or considering restoring the iphone or ipad.
