Texts messages aren’t sending in green
Tyl1
Why can’t I receive and send text messages to anybody I can still call people but not texting
11 REPLIES 11
@Tyler011995 hi there have been issues the last couple of days with plan changes meesing up , you need to contact customer service agent to fix it for you
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
Tyler011995
I did that as well!
Tyler011995
I just did that and nothing worked still
Tyler011995
Yeah I did actually
RossN
@Tyl1 did you do a plan change for your renewal ?
darlicious
@Tyl1
Try rebooting your phone.
Tyl1
I honestly haven’t touched anything everything was working perfectly fine yesterday
Tyl1
Yeah I have an iPhone 13 pro max and I just checked and everything is enabled and I just laid my bill last night
will13am
@Tyl1 , by chance did you have a renewal take place in the past couple of days?  If so you could be affected by a renewal glitch.  If so you need to use the chatbot link to initiate a support ticket.
darlicious
@Tyl1
Did you accidentally enable chat features? Or RCS? Usually the chat bubbles come up in dark blue rather than the light blue but you can check in your messaging app settings by going to the three dots at the top right corner of your screen. Click on settings and go to advanced and you should find your chat features setting in there toggle it off if it's enabled.
RossN
@Tyl1 hi you have an iphone? go to your settings ,messages enable send as sms and mms
