01-13-2023 05:52 PM
My tax rate is still based on Ontario even though i lives in Alberta now, also not getting the data promotion offered.
01-13-2023 06:28 PM
01-13-2023 06:06 PM
Your tax rate you pay depends on which province you have a phone number, set up in. It doesn't matter where you live.
01-13-2023 06:04 PM
are you still using an Ontario phone number? tax rate are based on the "location" of the phone number, area code. So, if you are still using a phone number with a Ontario area code, you will get charged with Ontario tax rate
However, there is a workarorund to save the tax. Get a voucher from store in your area. For voucher, it is taxed based on the tax in your province. Then you can load your voucher using *611 or My Account. it is a bit of work, but probably worth it
01-13-2023 06:04 PM
HI @christy817
if you are talking about the data bonus from Christmas, you can try to open ticket with CS agent and see if the can still add it back for you
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
01-13-2023 05:54 PM
@christy817 wrote:My tax rate is still based on Ontario even though i lives in Alberta now, also not getting the data promotion offered.
To get the reduced sales tax, you would need to change your phone number to an Alberta number. Which data promotion are you asking about?
