TXT Message Received : 'Plan did not Renew'
Monty2016
Got the following text.... 'Your plan did not renew because we did not receive your payment.' AutoPay is enabled on the account (checked) so I am not sure why I am getting this message or why it didn't renew as expected. I could pay it manually but I will wait because I would like this to work as designed and if there is an issue, find out what it is and solve it.
Thanks.
Monty2016
Thanks for the help guys. I have sent a PM to the moderators. I await there answer.
Korth
@Monty2016
You should still login to your Self-Serve and check the transaction history.  See whether any charges were made, see whether AutoPay reward was applied.
If so, the issue might correct itself by the end of the day, a technical or billing glitch (which hopefully won't recur every billing cycle, lol).
But if not, your account will remain "suspended" until you manually reactivate it or the @CS_Agent is able to correct something on their end (which they won't be able to do if they're unaware of the problem, lol).  You can message the mods - with your account #, phone #, name, address, etc - to speed things along, if necessary.
The account and phone number won't be lost until they remain suspended for at least 90 days, don't panic.  Although it does suck to have no working phone, especially after setting up auto payments, lol.
will13am
@Monty2016, if you do not want to intervene manually, I suggest sending a private message to the moderator team to investigate why the auto pay did not work.  The moderator team can be reached via private message using this link.  Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
