10-09-2023 05:17 PM
Hi guys do you have any idea if switching from my current plan of 20gb (total 60 gb in 3 mos.) 90 days contract to 40 gb 90 days($40 per month) contract would make my old rewards obselete? Will I be switched automatically to Public Points? I want the old reward system that I have. I just want a peace of mind lol. Thanks
10-09-2023 11:58 PM
I just switched from a 30 to 90 day plan and I kept my rewards, no need to worry. I would check though, on the day your plan renews, to make sure the transition applies correctly. My plan was scheduled to switch over today and it failed to do so automatically, so I had to manually check out to get service back.
10-09-2023 05:26 PM
No worries. You will keep the legacy rewards with plan changes. You will need to manually switch over to points system (not recommended).
