11-20-2016 07:06 PM - edited 01-05-2022 12:44 AM
Did not read the forums about porting over from Koodo before activating my new account. I used the same email and I've now seen that this is apparently a problem. I think it would've been considerate to have told customers switching over that this would cause problems. If I have only one email, I would naturally use the same one when signing up. Anyways, I am still currently using my koodo plan as I don't want to use the number that I was forced to choose from PM. I feel that it is a waste of money paying for two plans when I want to be rid of Koodo and just use PM with my old number. I am a bit frustrated and would highly appreciate some assistance.
Thank you
11-24-2016 06:49 AM
11-24-2016 12:00 AM
11-23-2016 11:55 PM
yeah, if i check eligibility the web page crashes and if I try to do it without checking eligibility it won't let me cause it says I need to be authorized. I am the only account holder so I am definetely authorized. It may be happening because I've already tried to port. Either way I'm really unhappy that I can't get a hold of anyone from PM to help me.
11-21-2016 08:15 AM
11-20-2016 07:18 PM
11-20-2016 07:18 PM - edited 11-20-2016 07:20 PM
No thats fine i have friends that ported from koodo with same email. just make sure when you port you have correct account number, pin, alternate number, and name. The credintials have to be exactly the same as they are on your koodo account. good luck!
11-20-2016 07:16 PM
11-20-2016 07:10 PM
Just thought I would add that I used the same email and ported my Koodo number over with no issues. It doesn't mean that you won't run into problems but thought I would let you know. The only other situation where I've seen problems was when the person was on Koodo prepaid.
