12-04-2022
11:51 PM
12-04-2022
11:55 PM
computergeek541
Hello
Regards to Free addon of 2GB, the speeds are plan dependant + other variables?
Also if last years Christmas Bonus of 2 GB and 500 Int. LD. Mins. are not used up will you still receive this years gift after receiving and accepting offer?
Email was received, waiting on text from Public.
"Free $0 add-ons are one-time only and will fall off account when fully used. Each free add-on will only be added to each customer account once. "
Merci
12-05-2022 07:51 AM
@Me0W I'd assume the bonus will match your plan.
In the past, I had 3G and the bonus would give 3G data. I'm on 4G this year so only time will tell, but I'm not sure how they would give me 3G data when my plan is on 4G. That would sound like a headache to throttle peoples plans up and down to differentiate the two...
12-05-2022 02:10 AM - edited 12-05-2022 02:19 AM
There is an old grandfathered plan without any data included. The data speed will be full 4G speed.
I just did a speed test and wasted 34 Mbps data on my $13 50/50 plan which does not include any data.
Sorry. I got distracted and post this post toooo late and repeated information.
12-05-2022 12:25 AM
@hairbag1 wow, the public mobile site is really glitchy, I just checked your post 2 seconds ago and you did not even have a responese on my screen, but now you do. This site needs some making fixing
12-05-2022 12:00 AM
I haven't used up my 500 Int. LD. Mins from last year. You will still receive the gift for this year and just need to reply "Yes2" and it will add on 2GB and 500 Int. LD. Mins.
12-04-2022 11:59 PM
@Me0W wrote:Hello
Regards to Free addon of 2GB, the speeds are plan dependant + other variables?...If your regular plan has 4G...the add-on data is also 4G.
Also if last years Christmas Bonus of 2 GB and 500 Int. LD. Mins. are not used up will you still receive this years gift after receiving and accepting offer?...yes; it'll just show up as another 500 minutes of Internationall calling add-on.
Merci
12-04-2022 11:55 PM - edited 12-05-2022 07:00 AM
@Me0W wrote:Hello
Merci
The speed is whatever the speed is of the rest of your data in your plan (or 4g speeds if you have a $13 plan that doesn't have any data). You will still receive free long distance minutes even if you haven't used the minutes from last year.
12-04-2022 11:54 PM
@Me0W You keep all the add ons you got before, and it does not affect anything. You will get this years as well. The speeds as far as I am aware is depending on the speed of your plan and that is it. So a 3G plan has a 3G speed addon and 4G plan has a 4G speed addon. If switching between the two, it takes up to 48 hourse to see the speed increase
