Speak with an agent
Ger5
@Ger5
PM is Canada wide calling and texting but if they are outside of Canada. It would be an issue with the caller’s plan they are on.
You might consider using WhatsApp for free calling and texting when connected to wifi or data but both parties must have this app.
SML90
It sounds like the issue is related to long-distance coverage. A few things to check...
Plan Settings: Make sure your plan supports incoming long-distance calls. Some plans may restrict these unless explicitly included.
Caller’s Service: If the person trying to reach you doesn’t have long-distance enabled on their line, the call may not connect.
Ger5
Callers who don't have long distance coverage are unable to reach me on how my plan is set up?
