04-10-2022 06:46 PM
I made a payment on my bill. My phone was activated .But my second phone which is also on my account was not.
04-11-2022 12:04 AM
There is a “reactive” button on the account if adding enough funds doesn’t cause it tomreactivate on its own. But, if you have had it deactivated for awhile, might you have exceeded or come close to the 90 day maximum? If so, it’s done….
AE_Collector
04-10-2022 08:29 PM
The community may be able to narrow down the issue will just need more info to diagnose the problem.
04-10-2022 07:35 PM
@shanemelville01 wrote:I made a payment on my bill. My phone was activated .But my second phone which is also on my account was not.
@shanemelville01 Try registering an account for the 2nd phone number you have with Public Mobile here: https://selfserve.publicmobile.ca/self-registration/
Once set up you can use the same credit card as your 1st account for Autopay or payments.
If for some reason you cannot register for an account for the 2nd phone number, because it is saying an account already exists, then perhaps somehow 2 accounts got connected to one email (which conflicts the accounts). In this case, you will need to submit a ticket with customer support agents (CSA) to add a unique email to the 2nd account.
To contact Public Mobile Representatives (CSA), by either two methods, found here:
04-10-2022 07:31 PM
Hi @shanemelville01 your 2nd phone is on a different My Account login? one email login for one phone line. You said you made a payment and your first line activated? Are you talking about new activation? Or you meant plan renewal? please give is more info to your situation
04-10-2022 07:02 PM
Do you mean using the same SIM on the 2 different phones?
Only 1 phone number/account is permitted.
If your second phone had a different number with a different SIM. Have you kept up with payment within 90 days. If not,
your second account will be closed and number lost.
04-10-2022 06:49 PM
Are both phone numbers at Public Mobile? Public Mobile doesn't issue a bill, so there's no way to owe money. Also, there can't be more than one phone number on the same account. Payments have to be done seperately to each.
