Saving link to each account
Runningdog
With two separate accounts different emails for each, but both in my name, I cannot save each account link on my computer separatly.  If I save one with freshly-entered password, the second account is saved with the same password and account number.
Stumped.
roamingelephant
Use a password manager like LastPass.
NDesai
You might want to just save email and password for both accounts. When you want to access it, simply login using the saved email and pass. There is no way to remember both sessions so it stays logged in, but you must logout to switch to another account.
_________________________________________________________________________________________________
If you need to contact PM Customer Support Agent, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
Stumped.
Because they're the same link
https :// selfserve. publicmobile. ca/ Overview/
Log in credentials are held elsewhere. Cookies etc. Maybe a password save might do something for you.
ChuckYeah
Are you trying to set a shortcut on your desktop?
