02-20-2023 10:01 AM
Has anyone had problems using Samsung Galaxy A14 5G with Public Mobile Network?
02-21-2023 05:29 PM
@johnluk We all happy to hear it and welcome to public mobile 🙂
02-21-2023 05:26 PM
self solution removed
02-21-2023 05:20 PM
The Samsung Galaxy A14 5G works GREAT on the Public Mobile Network. Thank you everyone for your helpful comments.
02-20-2023 01:06 PM
@johnluk- I hope you turned off subscription notifications for these additional replies along with this one. There are some extra helpful users here that didn't see your last reply.
02-20-2023 12:59 PM
@johnluk if yours is a Canadian model of A14, it should be fully compatible.
But confirm the model you got , check Option-About and see what exact model number is that.
But in most case, even a non-Canadian version should work ok , although might not be great.
Are you getting some drop calls issue? or not connected to the network at all?
02-20-2023 12:55 PM
@johnluk wrote:Just checking at this point. What to make sure it will work on Public Mobile Networks.
What issue do you have? If it's data, then make sure APN setting is correct:
https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-a14-5g
02-20-2023 10:09 AM
02-20-2023 10:07 AM
Looks fine. What problems are you having? Try setting networks to LTE/3G/2G if maybe it's set to 5G etc. There's no 5G here so may as well not try finding it.
02-20-2023 10:06 AM
@johnluk - looks compatible, https://www.kimovil.com/en/frequency-checker/CA/samsung-galaxy-a14-5g
Are you having issues with one, or just checking?
02-20-2023 10:03 AM
@johnluk Shouldn’t , it’s compatible
