07-16-2020 03:19 PM - edited 01-05-2022 12:08 PM
Does any know if the
Samsung Galaxy A10S A107M/DS is compatible with Public Mobile, this phone is not a Canadian model.
09-07-2020 03:12 PM
I solved the data connection issue. I reset all my network connections, deleted all the previous APN settings and turned off my phone. I restarted my phone and used the APN settings on my daughters phone, on my phone.
I SAVED the settings and turned my phone off and removed the sim card.
I restarted my phone and it was on the data network connected via LTE.
SWEET.
I treated it like a software installation on a PC and deleted the old settings first, then restarted.
Entered the new settings, SAVED it and restarted.
Success ... data network connection is achieved.
I did not swap out my sim card as that may have compromised her service.
09-07-2020 02:33 PM
I did that last month with a MOD Violette, it connected for 3 weeks and was dropped by the network last Thursday night Friday morning. It worked for 3 or so hours late Friday night after assistance from MOD Carlos but Saturday afternoon it went out again. I'm fixing it now, or at least trying to.
09-07-2020 02:26 PM
@bocca if you or daughter is with PM switch the Sims. If its the SIM ask for it to be provisioned. Stay safe.
09-07-2020 02:18 PM
I have an A10s and got dropped from the mobile data network twice, July, and last 9/4 Past. Both occurring 1 week after my payment. I am seeking a refund or credit for my data payment as I type this.
The device radio is compatible on paper, but not in practice - for my handset. My daughter has the same model and has no network issues. I have checked my device through a samsung repair facility under warranty and the device is flawless, for being 7 months old.
The self help directions worked last month, but they are failing so far since Friday, 9/4. I'll reply when I get the final result.
07-19-2020 10:24 PM
U can give a check with the IMEI number on the website which is found on the settings of the phone
07-16-2020 03:23 PM
@BillS Yes, it is compatible with PM and its service. You are good to go.
07-16-2020 03:23 PM - last edited on 07-17-2020 01:37 AM by computergeek541
@BillS wrote:Does any know if the
@BillS Yes it will work with Public Mobile and all other Canadian carries without any issues.
3G bands | UMTS 850/900/1700/1900/2100 |
4G bands | LTE Cat4 (Bands 1, 2, 3, 4, 5, 7, 8, 12, 17, 28) GPRS, EDGE, UMTS, HSDPA, HSUPA, HSPA+, LTE |
07-16-2020 03:22 PM - edited 07-16-2020 03:22 PM
@BillS hi yes, this phone has the correct frequencies to work with public mobile
