09-22-2022 01:05 AM
I changed to a higher data plan while I was away from home and now would like to go back to my old plan. However I don’t see that same plan option available now that I want to change back to it.
09-22-2022 10:47 PM
@Leano wrote:Thanks for your answers. I was afraid that was the answer, and I wish I’d known that and had just added some data to my original plan which was soooo good 😞 $20 for 2GB per month.
self given solution removed
09-22-2022 10:28 PM
09-22-2022 01:49 AM
if not see same old plan, move on to new plan, and keep looking on site maybe is coming new offer.
09-22-2022 01:07 AM
What was the old plan?
Indeed, if you change out of a plan that is no longer offered then you can't go back to it.
09-22-2022 01:07 AM
@Leano wrote:I changed to a higher data plan while I was away from home and now would like to go back to my old plan. However I don’t see that same plan option available now that I want to change back to it.
Sorry, but you can only change to currently offered plans. Which plan where you looking for?
