10-05-2025
01:33 PM
10-05-2025
10:58 PM
computergeek541
10-05-2025 01:44 PM
Thank you I submitted it
10-05-2025 01:41 PM
If it is a phone issue, put the sim card in another phone and you can then receive text and reply
But if you want to ask PM to help, open a ticket Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
10-05-2025 01:40 PM
@Glu7772 wrote:Hi
I need a manual release of my phone number. Please help
You'll need to contact a CS Agent via ticket.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
