12-29-2022 03:16 PM
I used a refer a friend code when I signed up but didn't receive my one-time $10 off my bill. When will I see this applied to my account?
12-30-2022 01:00 AM
I have already received my bill for my second month, and no credit was available or applied...
12-29-2022 06:11 PM
The $10 credit will apply to your next month bill and you will see it in your account after 3 days.
12-29-2022 03:22 PM
HI @MHA if you are the one who used the code, wait 72 hours and you should see the $10
If not, please open a ticket with CS agent
at : https://publicmobile.ca/chatbot.
Start by Typing: My rewards are missing,
Select "Public Points"
click on "Refer A friend",
then click on "Yes, I'm the referred customer',
finally click "Click here to submit a ticket" .
12-29-2022 03:22 PM
Thanks I have sent a private message as I was unable to open a ticket. I have been using public mobile for over a month now.
12-29-2022 03:19 PM - edited 12-29-2022 03:19 PM
@Handy1 OP is the "friend" who used the code
The one newly activated, who used the code, will be the one who opened ticket in this situation
12-29-2022 03:18 PM - edited 12-29-2022 03:24 PM
@MHA sorry miss read post
12-29-2022 03:18 PM
@MHA the referral code will be applied to your account as Available Fund within 72 hours
If it has not been 72 hours, please wait
If it has been 72 hours, please check again using incognito mode and see if you see it there as Available Fund
If still not find it there after 72 hours, please open ticket with Pm Support using Chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
