Re: Long distance calls to the US.
gghateslowweb
Glad to see Public Mobile made the smart decision to re-instate this, I was in the middle of researching which company to switch to.....
Now the problem is that the online website account does NOT show which/any Add-Ons active on the account. This is only visible in the app!?
hi @gghateslowweb
Login My Account go to Subscription & Add-ons, then change to "Minute" tab or use this link
https://myaccount.publicmobile.ca/en/account/manage/shop/addons
and here you are
1000 U.S. Long Distance Minutes
gghateslowweb
Ah thank you! I looked everywhere and couldn't find it, doh!
hi @gghateslowweb
the site has that too.  You just need to click Usage Breakdown under the Usage Odometer on the front page
