Ran out of data,topped up,account active and still no data on phone
CarmelleL
10 REPLIES 10
@CarmelleL wrote:
I have done that,but still not working
@CarmelleL - if is possible you missed the 2nd step of adding addons to accounts.
Purchasing an addon is TWO STEPS. Be sure to:
1. Add funds to your account, if you don`t have sufficient funds
2. Go back to the Add-Ons page and select your Add-On.
If you do not see the addon listed under this section (below), then you did not successfully add it to your account yet. If the $'s are still sitting in your Available Funds, go back and do step #2 above.
You have a few options for data depending on what you want to do. You can buy an add on either with the available funds in your account or your reward points if you are on the new program and have enough (would actually work out to a bit of a discount) and get 1GB of data to hold you over to your next renewal, or if that is still a ways off, you can either change your plan to the next highest amount to get you more data (you can do this yourself by changing immediately) If you want to stick with the same plan you have now you cannot do that yourself and will have to connect with a CSA and get them to manually pay for your current plan to start right away (as long as you have the funds in your available in your balance you will be good to go for all options)
CarmelleL
Not sure I know what you mean
CarmelleL
Not given the option
@CarmelleL wrote:
How do I do that
HI @CarmelleL
If you have enough fund in the Account and ready for renewal, just open a ticket with CS Agent.  Once they got the ticket, and validated  your identity, then they can renew early
To open the ticket,  at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
Do you see a line saying something about data under your my data & add-ons on the overview page of your account?
CarmelleL
How do I do that
CarmelleL
Ho @CarmelleL The fund you topped up appears as Available Fund in My Account?
how many more days before the next cycle? do you want to renew early?  If you want early renewal, you will need to open ticket with CS Agent.
dust2dust
Topping up alone doesn't do anything until you renew or buy add-ons or change plans. This is not pay as you go. So use the money you put in to buy a data add-on to hold you over until your renewal.
