05-17-2022 06:29 PM
05-17-2022 06:34 PM
Topping up alone doesn't do anything until you renew or buy add-ons or change plans. This is not pay as you go. So use the money you put in to buy a data add-on to hold you over until your renewal.
05-17-2022 06:45 PM
Ho @CarmelleL The fund you topped up appears as Available Fund in My Account?
how many more days before the next cycle? do you want to renew early? If you want early renewal, you will need to open ticket with CS Agent.
05-17-2022 07:20 PM
I have done that,but still not working
05-17-2022 07:21 PM
How do I do that
05-17-2022 07:22 PM
Do you see a line saying something about data under your my data & add-ons on the overview page of your account?
05-17-2022 07:23 PM
@CarmelleL wrote:How do I do that
HI @CarmelleL
If you have enough fund in the Account and ready for renewal, just open a ticket with CS Agent. Once they got the ticket, and validated your identity, then they can renew early
To open the ticket, at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-17-2022 07:28 PM
Not given the option
05-17-2022 07:30 PM
Not sure I know what you mean
05-17-2022 07:43 PM
You have a few options for data depending on what you want to do. You can buy an add on either with the available funds in your account or your reward points if you are on the new program and have enough (would actually work out to a bit of a discount) and get 1GB of data to hold you over to your next renewal, or if that is still a ways off, you can either change your plan to the next highest amount to get you more data (you can do this yourself by changing immediately) If you want to stick with the same plan you have now you cannot do that yourself and will have to connect with a CSA and get them to manually pay for your current plan to start right away (as long as you have the funds in your available in your balance you will be good to go for all options)
