02-11-2021 02:00 PM - edited 01-05-2022 05:14 PM
02-11-2021 10:36 PM - edited 02-11-2021 10:37 PM
So I looked up the number for TfL (Transport for London), and it is listed as 0343 222 1234
https://tfl.gov.uk/help-and-contact/
So, adding +44 (hold 0 to type a "+" ) and dropping the 0, the number becomes:
+44 343 222 1234
Or, using 011 in place of the "+":
011 44 343 222 1234
I was able to successfully call the number with both of those formats.
Please test with the above numbers, and this will confirm if your calling is working or not. If so, re-confirm the number you are trying to dial.
02-11-2021 05:00 PM - edited 02-12-2021 01:37 PM
@Ashley10 wrote:Purchased 1000 U.K talk minutes and payment has gone through successfully. It appears on plan details but isn't working. Turned phone on and off, when I try and ring - it tells me talk is not included in my plan.
@Ashley10 Make sure you're omitting the zero that's part of the 4 digit local area city code.
02-11-2021 02:28 PM
Make sure the number you are trying to call does not have any of the following UK codes.
Calls made to numbers starting with the following UK codes are not included in UK calling from Canada and will not be completed when dialled: 4470, 44870-44879, 44843-44845.
02-11-2021 02:27 PM
@Ashley10 : Can you confirm that K is a K and not an S? There's also a 1000 minute US add-on.
02-11-2021 02:02 PM - edited 02-11-2021 02:04 PM
Can you confirm you are dialling correctly.
To call United Kingdom from Canada, dial:
011 - 44 - Area Code - Land Phone Number
011 - 44 - 10 Digit Mobile Number
