02-07-2022 08:29 PM
Hi folks, newbie in this community! I would like to ask is there anything I need to do after I purchase an add-on for minutes to Philippines? Do I have to activate something or it is ready for long distance call as soon as I purchase the add-on minutes to the mentioned countries?
Thank you so much for your help!
02-07-2022 09:41 PM
Thank you so much @VIP_Tech
02-07-2022 09:41 PM
Thank you so much for you reply!
02-07-2022 09:37 PM
Try it.
If call goes through, you did it right.
If not, you didn’t.
You can’t be charged ‘extra’ for trying - if an add on wasn’t purchased, it just won’t work.
02-07-2022 08:39 PM
call from canada to philippines
01163 2 xxx xxxx
02-07-2022 08:34 PM
@geliemaeeviota Two steps to buy an add-on.
1- add money to account
2- Click Purchase add-ons and then find the add-on you want to buy and buy it.
Then it should appear on your overview page under my data and add-ons.
02-07-2022 08:34 PM
100 Philippines Long Distance Minutes = $15
How To Purchase Add-Ons through Self Serve (publicmobile.ca)
and Rebooting device.
02-07-2022 08:31 PM
Should be ready to go. Log into self service to make sure it is listed under My Data & Add-Ons.
