08-13-2022 09:17 PM - last edited on 08-13-2022 10:22 PM by computergeek541
I have a Pixel 6 and just recently, I got the notification saying I need to sign into network to use my data. I've used up all 250mb of my monthly plan, but I still have total of ~1GB left from add one. I don't know why it stopped working today, but it always worked in the past where I can just use the add on data automatically after I used up my monthly data. How do I fix this so I can continue using my data?
08-13-2022 10:22 PM
It was the cache issue with my browser. I can see that I used up all my add-ons when I signed in using incognito. Thanks for the help!.
08-13-2022 09:50 PM - edited 08-13-2022 09:51 PM
@albertlin There is a chance that your 1GB add-on is also used up. Sometimes you were just showing the cached result and it is not up-to-date. For more accurate count of data, login with Incognito mode or login with a different browser (Edge/Firefox/Chrome).
And if you are on Android, make sure you don't have data limit enabled it could be your device blocking your internet because you reached the limit setup on your device
08-13-2022 09:27 PM - edited 08-13-2022 09:30 PM
@albertlin - if you see your addon still remaining on your My Account then try:
edit: but, if you don't see your addon, then it may have been used all up. Regular Addons stay on your account until used up.
