02-22-2023 08:48 PM
Public Mobile here. Welcome to USA!
I’m more than 5 kms from the border in Abbotsord, BC. The only change I have done to my phone has been installing the latest Apple IOS. Anybody else experiencing similar issue?
You can get a U.S. roaming add-on for as low as $10 for 15 days. Customers using Roaming Add-Ons may experience differences in coverage and service quality (including 9-1-1 calls) due to certain U.S. carrier 3G network shutdowns. Go to https://selfserve.publicmobile.ca/ for Add-On options. If you no longer wish to hear about Public Mobile offers, visit bit.ly/1n8ObE2
02-22-2023 09:45 PM
02-22-2023 09:44 PM
thanks @TH04 🙂
02-22-2023 09:42 PM
IOS is 16.3.1. Yes, red dot does show up if it’s a missed call, usually a number that is not in my contact list so the phone does not ring. Haven’t had any voicemail recently, but I will assume a red dot will appear. The phone is an older 8 Plus.
02-22-2023 09:06 PM
Hi @TH04 yes, OS update can be torublesome sometimes 🙂
hey, which iOS version you are on now? can you confirm if you are getting voicemail notification badge (the red dot) ? We see mixed experience and people wonder if it has to do with iOS update
thanks
02-22-2023 09:01 PM
It’s an iPhone. All fixed now b thanks.
02-22-2023 09:00 PM
Apple update changed my settings. All fixed now.
02-22-2023 08:59 PM
Thanks softtech. The latest IOS update changed my settings. All fixed now.
02-22-2023 08:57 PM
Thanks for the reminder and tip hTideGnow. I guess the latest IOS update changed my settings. I have once again changed the “automatic” setting.
Cheers
02-22-2023 08:52 PM
Most likely do to proximity of USA your location is 'recognized' as you being in USA. Nothing is perfect
02-22-2023 08:51 PM
Hi @TH04 what phone do you have?
Just choose manually to select Public Mobile as your network instead of using Automatic.
02-22-2023 08:50 PM
Yes, US signal is usually a lot stronger than Canadian network. Your phone is set to automatic and usually will pick the strongest. signal
What you can do is to go to network selection, change it from Automatic to Manual and select Public Mobile to lock it with PM network
