Province wide to Nation wide calling upgrade
Toronto416
Hi,
I recently moved from Ontario to BC, my current plan only has province wide calling. I want to upgrade to nation wide calling keeping everything else the same. Is it possible? hope it wont cost a ton! Im a loyal PM customer with several referrals, have been loving PM since day 1
9 REPLIES 9
Acekiller
depending on how much call (and from where) you may just want to get the $15 400min add on, it gets carry over if you don't finish up the minutes.  For outgoing you can use Gtalk for long D and just save the 400 min strictly for incoming.
SD08
@Toronto416 wrote:
Hey Hey!! thanks for your valuable reply!! 😄
So is it true if I dont change anything, I can make outgoing BC Calls and on 1800 numbers for free? Kindly advise!! Much appreciated 🙂
@Toronto416
Yes, you would be able to make outgoing calls to within BC, and calls to 1800 numbers.  You won't be able to receive calls though.  Here's a chart that illustrates how PM's province-wide calling works: http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Province-wide-Canada-wide-and-Long-Dist...
Toronto416
Pier
@Toronto416
If you really wanna keep everything the same, you can just change number...... a BC number will help you keep your existing plan and buy add-on to call nation wide.
Yours,
One option would be to just change your phone number, but remain on your current price plan.  However, you woud then need a long distance add-on to call back from BC to Ontario, and people in Ontario would have to pay for any applicable long distance to call you.   For outgoing calls you could use a VOIP solution for reduced-cost or even free long distance calls back to Ontario.  Public Mobile also offers small amounts of long distance minutes that can be used on top of your base plan.
If you keep your current Ontario number while you are in BC using your current price plan, you will not be able to receive any phone calls.  You will still be able to make outgoing calls to BC phone numbers.
To swtich to nation-wide calling, you need to have a plan change processed.  For regular-priced plans, the difference is usually $5 more per 30 days.  This can only be done by doing a full plan change though, as it is not possible to just add the $5 as option on top of your current provincial calling plan.
True add on will be better option
Let's assume if you have a 12gb 90 Days plan which is 120 dollars and if you want to change nationwide then it's 201 which is like 27 dollar extra per month if you break down to monthly 81 dollars make a difference
Cuz I have that plan I was thinking about changing to add usa calling but that was making a big difference in prices but my fellow friendly users need mod suggest to use either usa add on or third party app to call usa on data or WiFi without touching My lovely plan
It all depends how often u used calling features if you need lots of air time or limited hope you got your answers
** I am not a Mod, please do not include any private info in a private message to me.**
mimmo
depending on how much calling you pand to make the other option is to buy the long distence addon.
It's will make a big difference i am guessing u are on promo plan if u want to upgrade to nationwide then u pretty much losing your old plan and will cost according to new customization plan
SD08
What is your current plan? Is it a promotional or grandfathered plan?  If you make any changes to such a plan, you won't be able to go back to what you had later.
Also, because PM is a prepaid service, there are no refunds for what you've paid already. If you make changes that start immediately, you would lose whatever you paid for previously, as you can't just upgrade and pay the difference. You'd be paying the entire cost of a new plan. Alternatively, you can go into your PM self-serve account and select your new plan and future date it to start at the end of your current subscription. That way, you won't lose anything, but you will have to wait until it takes effect.
In the meantime, you can use a free internet-based VOIP app like fongo, to make and receive free calls across Canada. It only needs data or wifi to work.
Currently, PM has this available:
90-day: Canada-wide Talk + International text + 3 GB data $126
90-day: Canada-wide Talk + International text + 6 GB data $135
90-day: Canada-wide Talk + International text + 12 GB data $201
All these plans are rewards eligible.
Btw, please don't post any personal information such as account number here on this public forum. That kind of information should only be included when you send private messages to moderators for action on your account. You should edit your post to remove this.  (Click the three dots in the upper-right corner of your post to edit.)
