04-27-2023 11:47 AM - last edited on 04-27-2023 05:09 PM by computergeek541
I changed my number in August 2022. I have an account with a store that is not allowing me to change the number without proof that I was the account holder. I no longer use the email associated. How do I get proof that i was the holder of my old number? I tried to download my old bill but it's only showing the account number
04-27-2023 12:41 PM
It occured to me afterwards that do you still have any emails from that store from back then before you let the email address go? Like old items in all inboxes. I keep just about everything digital.
04-27-2023 12:22 PM
HI @Mochasplash what are you trying to do? trying to port a number out?
you can just provide the IMEI number to the new provider and they might be able to do so
if not, then submit a ticket with PM and ask them the account number.
But You said you don't use the email associated but you can download the bill, the account number with the sufficient for porting
04-27-2023 12:07 PM
Quite the conundrum. This link shows an old style invoice. I'm not sure what it would have now. But it had the number on it then. You would need to ask support as above.
04-27-2023 12:00 PM
@Mochasplash You change the phone number via login to My Account
Understand you cannot login to My Account now, open ticket with PM support to get access back first:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
