05-12-2022 06:20 PM - edited 05-12-2022 06:21 PM
I purchased a voucher from SDM today, and it doesn't work. It says Unfortunately, Voucher # could not be added. Please verify the Voucher and try again. Do I wait it out? It usually works immediately after purchase.
05-12-2022 06:23 PM
HI @LeePublic SDM voucher should work immediately. I would not wait, just open ticket with CS Agent and let them confirm. At : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-12-2022 06:23 PM
05-12-2022 06:36 PM
I submitted a ticket thanks @hTideGnow
05-12-2022 06:45 PM
Are you using the 12 digit PIN #? Don't use the voucher #. If you have tried it twice already you have to wait out the hour. See this post in the voucher catalogue for reference....
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-12-2022 06:53 PM
I used the voucher# while submitting my ticket, will resubmit with the correct PIN#. Thanks, @darlicious
05-12-2022 07:01 PM
Did you try to enter the voucher twice? Has it been an hour? If it's been an hour call 611. Press (1) then (1) again and enter the 12 digit PIN #.
05-12-2022 07:09 PM - edited 05-12-2022 07:10 PM
Somehow it appeared in my account shortly after. Maybe they fixed it on their end.
05-12-2022 07:20 PM
Update: they solved it over PM. Case closed.
05-12-2022 09:54 PM
Glad you nipped it quickly and avoided any further headaches! 🙂
