a month ago
- last edited
a month ago
Quick question. When you try to enter the account number, and it doesn't work, do you get to try again, or do you have to contact PM in order to try again?
Thanks!
3 weeks ago
self solution removed
3 weeks ago - last edited 3 weeks ago
So, I transferred two accounts from Fizz to PM. Both with four zeros preceding the Fizz account number. Both failed, saying "wrong account number". Which it was NOT. I now believe the four zeros ahead of the 8 digit Fizz number does not work. A big thanks to the PM CSA team for manually doing the transfer both times, using the IMEI number!! (Be careful if you're thinking of doing it yourself using the IMEI. PM says that also leads to errors.) So, this topic remains without a solution. "Maybe" four zeros AFTER the Fizz number, who knows? But my problem was solved by the CSAs. Thanks again! We are now two new happy PM subscribers!
3 weeks ago
This is DriverMtl again, trying to activate my wife's account. Exact same problem. It says incorrect Fizz account number, which is not true. Submitted a ticket # 612114-194. I just hope they answer in time. Maybe someone is working on it, as I just received a SECOND text from Fizz, asking me to confirm transfer request.
a month ago
Hello @ DriverMtl,
I sent you a private message. You can view it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
a month ago
Thanks! I have the app, it is waiting for me to complete my activation. But the others ported from Fizz how? add four zeros or not? And before or after Fizz number? That's the part I can't seem to get a clear answer for.
a month ago
if you are still waiting for sim card, you are not at the stage of putting in porting request yet
after you got the sim card, download PM app, login and it will give you the chance to submit porting request. Many ported from Fizz without issues, so no worries.
just in case you need help, message them:
a month ago
Actually, I'm still waiting on my SIM card. I hope to activate with my phone # from old provider. It's just with all these horror stories about whether to add four zeros to the Fizz account # before, after or not at all, I'm quite worried. Nobody seems to have a definitive answer that works 100% of the time.
a month ago
it depends where you are in the Subscription process
if you actually gone all the way to step 6 and then get that error via email, then you will need to contact PM porting team. let me know and I can send you the number
but if you are still at step 4 for choosing phone number, then you can still choose new number
a month ago
So you are saying that when it doesn't work, you can immediately try again without having to contact anybody?
a month ago
You need to try it again. If the error is about not enough digits, add 0 to the front
If you still cannot get through that step, then get a new number first to complete activation and ask PM to help after
