10-02-2025 02:04 PM
It has been about 3 days and i can use my data and make outgoing phone calls but I cannot receive phone calls or Text in or out.
10-03-2025 07:41 AM
Sent, please check your community inbox
10-02-2025 06:42 PM
I'm kinda having the same issue. Can I have the number please? Thanks.
10-02-2025 02:07 PM
hi @Bill62
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
10-02-2025 02:05 PM
sound like a stuck port
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
