12-07-2024 03:49 PM - last edited on 12-07-2024 05:13 PM by computergeek541
I need immediate help. Not able to receive calls or text messages. Been a nightmare for the past 72 hours
12-07-2024 04:47 PM
The most critical part of porting your number is to reply to the text from Fido with YES you are porting over to PM with the Fido SIM in your phone. You have 90 minutes to reply or porting will not be completed.
If you Fido SIM still works then porting was not completed.
You will need a CS_Agent to complete the porting if you missed the text:
12-07-2024 04:44 PM
Hey @richardxvu60444
Before you contact anyone else, have you tried rebooting your phone? If you install your Fido SIM card and reboot, do you still have service? If not, that means the port has gone through (although may be stuck) BUT... if you go into network settings with your Public Mobile SIM card in the phone and then reset them and reboot... does that give you service? And finally, sometimes SIM cards need a kick in the butt, it's what's called reprovisioning a SIM card. The way to do this is to take it out, place it into another phone that's shut off and then start the other phone with the SIM card inside. If you have service on that other phone, the "kick in the butt" worked. Now you can shut down your phone, put the PM SIM card in that and restart the phone. You should be up.
If these don't work, then call any numbers that folks have sent you for extra assistance.
12-07-2024 04:01 PM
did you receive a text from Fido and did you reply Yes in time?
sound like the number not ported yet. But check with PM porting support team and confirm. I have sent you the number to PM Porting support team Please check your community inbox: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
