Porting from another carrier landline v cell
Cindy_6
When I signed up I clicked cell number transfer.  The number has not ported properly.  I have since found out that the number I expected to transfer was actually a forwarded number that had used some wizardry to be classified as a land line.  How do I fix it? Because I can only call out, I can not accept calls in nor text either way.
2 REPLIES 2
Chalupa_Batman
Hello @Cindy_6
Landlines can take up to 7 business days to port over. If you feel an error was made, you can create a ticket for a CS Agent to investigate.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
Meow
Talk to your previous provider to find out what kind of service did you have.
