02-25-2024
01:07 PM
02-25-2024
03:35 PM
computergeek541
Hello everyone,
I hope you guys have seen the new offer, where they are offering more data with US calling and data for many plans! So I told one more of my friend about this and he changed from Fido to Public.
I have helped him for the porting, but his number didn't get ported yet. He's been waiting to get ported since 9:30 p.m. yesterday!
I was wondering if it's a common scenario because many people are porting or what can be the thing and how long should we be waiting? I know when we get new offers, it takes time to get ported because many people might be going for it! So should I tell him to wait for one more day just to see if it works?
Thank you guys ☺️
07-02-2024 06:03 PM
Thanks for your help. I did figure out the message by the agent to whom I have replied and supplied the content of my message submitted in this Forum.
Thanks once again for being so helpful.
07-02-2024 05:50 PM
@ssmandur Best thing is to send a private message to customer support, use this pre-addressed link
Watch for an agent to reply at the envelope icon top right of this page or, if no envelope, tap your avatar for Messages.
07-02-2024 05:43 PM
My number stands transferred from FIDO. But it seems process at PM is having some glitch. I am able to send and receive calls on Telus network as usual. But on Rogerts network it is shown as Likely Fraud, Otherwise, the is getting through well. On Bell network it gets through with some intervention at the receiving end. Perhaps, the porting process at PM is incomplete. About messages, they neither sent out nor received. While sending out it refers to iMessage settings required. When trying to set the number My number shows blank. I tried entering 'My Number' in Settings in my iPhone, it is not saving and shows blank again. I think the esim and my number are not linked at PM. I tried resetting my network settings multiple times without any success. Already raised ticket which I am unable to see in my account here. Please help.
02-25-2024 02:58 PM
He's out for work so I guess I'll just meet him and then I will just tell him all of this in person
02-25-2024 02:52 PM - edited 02-25-2024 02:53 PM
@Shubh2023 Then maybe take out the old sim and put the PM sim in and restart the phone. Or does the old sim still work? Most carriers send an authorization text but not all do. If the PM sim doesn't work then put the old sim back and phone the number given.
02-25-2024 02:02 PM
He did not put the public sim in his phone yet. He's still using the same sim
02-25-2024 02:00 PM
He should pop his old SIM back in the phone for the text. It should still work.
DM a CS_Agent to restart the porting process.
There is a number for the porting he can call. I will DM you the number so tap your avatar top right then Messages.
02-25-2024 01:54 PM
Thank you so much for this long explanation and as mentioned by others, I guess he did not receive that message or maybe he did not see it
So what should be the next steps if he didn't receive the message yet to allow the request to go to public mobile?
02-25-2024 01:52 PM
I don't think he received that message yesterday because I was with him for the first half an hour but usually within the first half an hour, you can get the message
02-25-2024 01:35 PM
Here are the steps for porting from another carrier:
The steps must be followed in exact order if you are porting your number over to PM:
If all steps are followed, there could be provisional/backend issue with the SIM so contact a CS_Agent to fix at:
https://eversafe.id.telus.com/user/forgotemail?locale=en&ForceAuth=true
02-25-2024 01:15 PM
@Shubh2023 The common problem with porting is people not leaving the old provider's sim in their phone to receive the authorization request and/or not replying YES to the text within 90 minutes of receiving it. If that's what happened the port will need to be re-initiated. Once the old sim stops working then put the PM sim in the phone and restart it but it may take a little while before it works.
02-25-2024 01:13 PM
Awesome. That is very kind of you to do so!
Have a good one!
02-25-2024 01:12 PM
@Shubh2023 I’ll send. You the porting team number private message they can give you status update on the port request or re trigger it if needed
