Port my number
allen_salehi22
Hi, if I want port my number from Rogers, what kind of information do you need?
And also if I travel to US, still I can use my 50GB of data?
2 REPLIES 2
fixin
@allen_salehi22 - You will need your
  • Account Number from Rogers OR your IMEI from what your rogers sim is currently using.
  • Phone Number that you want to port
You can use 50GB in Canada and the USA. They are one bucket so if you run out in USA, you run out in Canada and vice versa.
There is Unlimited talk & text to an American number (Even if you are in Canada) You can also call Canada from the USA.
Make sure to reply 'Yes' and make sure it is your Rogers SIM that is making the text, (If you have a PM eSIM, I highly recommend disabling the PM eSIM for the port process to be steady. No further action needed for a Physical PM SIM.)
When your Rogers SIM has 'No Service' re-insert the PM SIM or re-enable the PM eSIM and you should be able to do anything like normal!
Sansan
 Hello @allen_salehi22Here's some information regarding porting your number. It depends if you have a Canada- US plan or  not in order to use your data. If you don't then you have to buy an add-on or buy a Canada-US.
Your Roger's account must be active and always best to use your account number, not IMEI.
https://www.publicmobile.ca/en/on/get-help/articles/transfer-your-number#:~:text=If%20you%20are%20ne....
